TwinTurbo.NET: Nissan 300ZX forum - Re: Do a voltage drop test.
coilerDH
on May 08, 2023 at 1:58 PM
posted by mrchips
on May 07, 2023 at 06:38 AM
I have ordered the battery cables from Z1. I will replace them and look into the relay trigger wire. Thanks for that suggestion about the voltage drop.
starter grinding
coilerDH
14:48:51 05/04/23
It could be a small section of teeth on the flywheel that
Polishzx
23:14:11 05/04/23
Have you changed the battery cables? If you still have the
LitlElvis
10:45:23 05/05/23
+1 on this
MyBlueZ
13:22:36 05/05/23
Re: Have you changed the battery cables? If you still have the
coilerDH
13:30:03 05/05/23
mrchips
06:38:57 05/07/23
Re: Do a voltage drop test. -
coilerDH
13:58:01 05/08/23
coilerDH
21:56:54 05/09/23
Re: starter grinding
coilerDH
22:00:13 05/09/23
coilerDH
13:04:00 05/10/23
